Recent Discussions
RSS
Posted by alank2 on Tue. Sep 23, 2014 - 01:26 AM
I wish Rigol made this price in Brazil too.. :(
Posted by jgmdesign on Tue. Sep 23, 2014 - 01:14 AM
The first 3 bytes are the company, the last 3 are like a serial number. Try 00-11-22-00-00-01 thru however many you have. This will work fine on a local...
Posted by LOSTISLAND on Sat. Sep 20, 2014 - 10:12 AM
I worked for an access control company years ago that created a cloud based access management system for a global network.  It was controlled via Internet...
Posted by vadim_123 on Sun. Sep 7, 2014 - 02:06 AM
thank you very much, I will try to change the encoding in the symbol table as you said, I have solved the problem in this way - I create an array of Russian...
Posted by EduardoLM on Mon. Sep 22, 2014 - 11:00 AM
Well, I edited the first post with real code, typo free. And I simplified the code with just one LED, because the issue occurs even using one LED and one LDR...
Posted by spgtl on Mon. Sep 1, 2014 - 02:59 PM
Just so you guys know, I have created a support case in my myAtmel login requesting that this is fixed. Case number 00005098 (not sure if that means anything...
Buzzing Topics (Last 6 Months)
RSS
Posted by brunomusw on Thu. Jun 12, 2014 - 05:59 PM
Thus we iranian are not lone. British and or even brazilians-self. :wink:
Posted by Michael@Atmel on Tue. Aug 26, 2014 - 12:04 AM
clawson wrote: Maybe its just me, but clicking on any links that I've found using google to "old" forum content just end up going to the home page of the new...
Posted by JohanEkdahl on Mon. May 19, 2014 - 07:32 PM
Quote:And hopefully someone will fix it now instead of waiting until we drown. This assumes that the vulnerability is currently exploited. I do not see...
Posted by bianchi77 on Thu. Apr 24, 2014 - 09:56 AM
JohanEkdahl wrote:Quote:Bianchi77, we want to know what you did that finally fixed your image shrinking code! You haven't figured out bianchi77's M.O. yet,...
Posted by ka7ehk on Fri. Jul 11, 2014 - 08:29 PM
I am learning an incredible amount of stuff from this. Never have formally learned about any of this, and it is both an eye-opener and comforting to be able to...
Posted by vigirush on Sun. Apr 13, 2014 - 05:50 PM
westfw wrote:It looks like micro controllers have an additional attack vector similar to return-oriented programming. This is impressive and I don't see any...
